KY Chris
- Louisville, KY
Hey, I know that some of you guys have built bumper/airtanks. What is the best way to prep/clean the inside of the bumper after welding?
KY Chris said:Ok... I am using 11gauge 3x3 box. I have figured I can get almost 7 gallons out of the bumper
Beezil said:don't worry about "prep"....
just do a fine job welding and you'll be good.
I find its easier to do an endcap that slides into the tube, so you can do a fillet weld in the 90-degree corners, rather than trying to seal the tank with an endcap that goes over the outside of the tube. you can always put a "decorative" endcap over the ends afterward.
KY Chris said:The bumper is 3x3 box, 9 feet long + another 5 foot section underneath. My rear quarters are cut, so the bumper is mitered and actually wraps around like a U. Beneath this 3x3 is another section of 3x3 that is 5 feet long. It's hard to explain, I'll have to take a picture, anyhow, it's roughly 14 feet of 3x3 which is 6.54 gallons.
Chris
