foxwar71
- Foxboro, MA
Built Dana 30 front axle - $1300
-Non disconnect HP housing
-1/4” heavy duty LCA mounts
-RE heavy duty PS UCA mount
-WJ UCA bushing on DS
-Boxed and reinforced coil buckets with sliders built into the front of them
-3” raised bumpstop pad built into lower coil buckets
-Custom heavy duty coil retainers with Grade 8 bolts
-1/4” Inner C gussets
-4.56 gears
-RuffStuff diff cover
-Lubelocker diff cover gasket
-297 shafts with newer Spicer 760’s and full circle clips
-WJ knuckles with JKS spacers welded on
-Teeves style calipers clearenced for 15” rims
-Extended Skyjacker SS braided brake lines included
-Tierod/draglink flipped for OTK with Goferit inserts
-JKS tierod and draglink with HD lifetime TRW TRE’s and RHD draglink piece for proper OTK
-Skyjacker drop pitman arm
-Relocated, boxed, and gusseted trackbar mount that ties into the UCA mount
-Custom trackbar made out of 1.5” OD .250” wall DOM, 2” Johnny Joint at one end and a 2” superride bushing (modded for 1/2” thru bolt) at the other end. Setup with RH and LH shanks for easy adjustablitity
-Spare parts included
-complete set of 297 shafts with BRAND NEW Spicer 760’s and full circle clips
-2 spare correct hubs
-BRAND NEW upper and lower WJ balljoint with hardware
-Spare yoke with extra straps/bolts
-All 4 BRAND NEW TRE’s
-Box of tons of spare bolts (hub mounting bolts, axle hub nuts and washers, etc)
-Any other D30 parts I can find
All the WJ related stuff and such only have a couple of thousand miles, u-joints and brakes only have a couple of hundred miles. Everything is in great working condition. Axle comes complete with everything needed to be swapped in; brakes, steering, brackets etc.
Built Chysler 8.25 rear axle - $800
-Factory 1999 housing
-29 spline
-4.56 gears
-Powertrax No-Slip locker
-Alloy shafts
-RuffStuff diff cover with custom pink middle finger
-Extended Skyjacker SS braided brake line included
-E-brake cables included
-Includes spare stock shaft
Skyjacker midarm subframe setup - $500
-Complete three piece subframe assembly
-Crossmember notched from more driveshaft clearence/droop
-LCA’s have 2.5” Johnny Joints with greaseable bolts at both ends
-UCA’s have 2” Johnny Joints with greaseable bolts at frame side, factory-style cup mount at the axle side to work with stock/stock-style D30 UCA bushing mounts
-I loved this setup and found it to work very well, the rear portion of the subframe does a great job of sliding on rocks if you encounter any big enough. It can flex enough to max out the shocks and unseat a coil. Great compromise to longarms while in my honest opinion being better then regular drop brackets
Skyjacker HD 6/6.5” rear leaf springs - $200
-Good shape, don’t sag at all even with all tools/spares loaded up
Skyjacker HD 8” front coil springs - $100
-Good shape, don’t sag at all even with a beefy front winch bumper
Rubicon Express HD trackbar bracket and brace - $100
-Great shape, only a couple of months old
-I’ll even included all Grade 8 mounting bolts
-Factory stamped sheetmetal upper mounting tab that goes thru the framerail on the bracket has been ditched and replaced with a ¼” thick piece with Grade 8 bolts welded on
Skyjacker 6-8” Hydro shocks (all 5) - $40
-2 fronts, 2 rears
-All bushings seem good and shocks are in working order
-spare front shock and spare boot included
Stock swaybar with Skyjacker 6-8” disconnects - $75
-Good shape, I stopped running a swaybar a long time ago so its seen little use
-Includes mounting brackets and bushings
-Removable pins have a small piece of rubber hose on them to reduce rattling noise
Rusty’s Offroad rockrails - $175
-Great shape, just some scraps and such, could use a fresh coat of paint
-Rear mounting brackets also reinforce the leaf spring mount
Super heavy duty rear storage setup - $125
-goes from the rear seat to the hatch and across from side to side
-Super heavy duty pullout drawer with double ball bearing tracks on each side (each one is rated for 200#, I had no problem filling it with all my tools and everything needed on the trail)
-Built from quailty plywood and hardwood, not cheap crap
-Sides flip up for more storage area, perfect for all spare fluids/straps
-Hidden area behind rear seat perfect for storing spare axle shafts and such
-Hi-lift mounts on top of the box
(5) 35x12.50xR15 Mickey Thompson Baja Claw radials - $500
-2 at 60-75%, 2 at 30-40%, 1 at 40%
-Mounted on (4) 15”x8” 10 spoke black steelie rims with 4” of B.S.
-Spare mounted on 15”x8” soft 8 black steelie rim with 4” of B.S.
-Also included is a 6th Baja Claw that has a small hole in the sidewall that could be vulcanized/tubed
(3) American Racing Outlaw II rims - $50 each/all three for $100/all three and tire for $150
-15”x10” with 3/3.5” of B.S.
-One rim has a 35x12.50xR15 Goodyear MTR mounted on it; very little tread left, spare condition
Dayton 6,000# winch - $200
-Brand new, never even unspooled
-Includes cable, hook, roller fairhead, controller, battery cables with quick disconnect plug
-Mounted on removeable receiver hitch mount
PACKAGE DEALS!!!!!
-Front & rear axles for $1800
-Axles, trackbar bracket/brace, subframe, springs, shocks, and swaybar for $2500
-Ask about other combos and deals
Not interested in shipping anything at this time, all prices are BEST OFFER, feel free to PM any questions/offers. for trades, i could be interested in some 37-40" tires, hp60/14b parts, maybe other stuff for my 1ton build
-4.56 gears
-29 spline
-4.56 gears
-Alloy shafts
-2 fronts, 2 rears
PACKAGE DEALS!!!!!
