Built HP30 and D44
Rockslut
Lincoln, CA
I currently have these axles under my XJ. They are driven daily and were on the Rubicon last weekend.
Front axle: $1400
Dana HP 30:
ARB air locker 30 spline Alloy shafts, Alloy USA joints
4.56 gears, 1/4" control arm mounts
Alloy USA axle seals, raised sway bar mounts
teraflex high steer knuckle, aluminum drag link
Solid diff cover, Lube Locker gasket and fresh gear oil.
Track bar mount raised.
Rear axle: $1200
Dana44 ARB air locker 4.56 gears
Teraflex disk brakes Solid diff cover, Lube locker gasket and fresh gear oil
Ubolt eliminator kit, flush mount shock tabs, spare shafts with new bearings and proper disk brake spacer.
They are turn key and ready to roll for someone looking for an easy upgrade. There isn't much more you could do to either axle to make them better.
I'm OBO on these axles. Would like to sell as a package.
