built high pinion d44
Vanimal
escondido, ca
selling my front axle. here's the specs:
ford high pinion housing
retubed with 3" 3/8" wall DOM
gusseted dana 30 inners
wj knuckles and brakes
5x4.5" wheel bolt pattern
about 64" wide, a few inches more than an xj axle
yukon grizzly locker
4.88 gears, installed in November
30 spline chromoly inners
chromoly stubs
spicer 760 ujoints with full circle clips
track bar included
brakes are in good shape
unit bearings are fairly new, comes with spares
newer ball joints, synergy chromoly joints on one side
set up for 3 link (passenger side upper link)
set up for coilovers but can easily be converted to coil springs and shocks with some coil buckets welded on
$1600
$1700 with brand new ruffstuff 3/8" welded diff cover
$1750 with spidertrax wheel spacers for the rear to make the axles equal length
Someone needs to get their tax return and buy this. Pretty easy to add coil buckets and shock tabs with Balastic's or Ruffstuff's brackets!
thanks, and i'd be willing to help weld on the coil buckets and shock tabs too. it wouldnt take more than an hour or so!
btw, sorry, not willing to ship
How much for the WJ knuckles and brakes? (=
Had to ask.
If you still have this when i get my tax return next week, i am interested.
not spliting it up just yet.
Let me know Aaron, i'd like to see it go to a naxja guy.
Will do.
Do you have the coil buckets/shock tabs? or will i need to get those?
How much of a deposit can he give you to hold this dan?He needs this BAD.I know we have been looking around for a setup for his junk.I mean jeep:)
if he's absolutely POSITIVE he wants it, i'd hold it. but that would require him coming to look at at and i know thats a bit far. dont really need a deposit.
still for sale! i'm going to cut off the coilover mounts pretty soon. will be cake to weld on some spring perches.
Dan i just heard from a little bird you'll be getting a call soon.PLEASE hold this.He has to talk to you about the spring perches from what i hear.:)
no worries scott. just havent heard from him so figured it was a no go. i dont mind holding it but i need to hear from him soon. cant afford to miss a sale from someone else and have him change his mind.
Re: Re: built high pinion d44
Sorry, was waiting on the IRS... they finally paid me. I'm ready to come take a look at it. What day would be good for you? I'm busy tomorrow, but any other day should work.
