xj4life
- LaPorte, IN
D44/9" - 5.13's and all the goodies
Front D44:
HD Late 70's high pinion D44 housing (1/2" think wall, narrowed to roughly 65" WMS), 5.13's, full detroit, yukon alloy shafts, yukon superjoints, crane inner knuckles, dedenbear outers (reamed for 3/4" bolt) with Sky Manufacturing high steer arms (both sides), 1310 yoke, 5on5.5. Set up for a custom link suspension (pass single lower, radius arm drivers side, track bar) with std coil springs. Would likely need to be stripped of brackets and new ones added on. New wheel bearings/seals, axle tube seals do not leak. 6deg of castor, pinion is at 10deg
Rear 9":
5.13's, full spool, 35spl alloys, nodular 3rd, 1310 yoke, disk brakes, 5on5.5, full size/big bearing housing. Setup for leaf springs. Probably needs a new housing (shaved but starting to leak a little) or reshaved. Also has (had) a tube/plate brace over the top that had to be hacked off the drivers side when i add a traction bar late last season.
Steering (included):
1.5"x.25" wall tie rod with 3/4-3/4 heims
Spare parts I will include:
- One full replacement Yukon Super joint
- Another set of Warn Premium Locking Hubs
- Might have a spare stub shaft or two
The Bad: ball joints need replacement, needs new rear yoke, already stated issue with 9" housing, Warn locking hubs that are on the axle now are a little beat up, tie rod is bent
Looking to get $2000 for the the pair. Will sell the D44 seperately but then I'm keeping the 9". Also willing to part out the D44.
Front D44:
Rear 9":
