broken hood (bonnet) cable - help needed
fourtayfour
united kingdom
have 1993 jeep cherokee 4L Ltd (right-hand drive) bonnet cable snapped
unable to lift bonnet (hood) - have tried taking front end off etc etc unable to get in has anyone encountered this problem - can advise how to do it - need to refill oil - screen reservoir etc urgently
would appreciate any advice - help
Headlights have to come out. Then there are 2 screws to be removed that hold the hood latches to the front body crossmember. Once the light bezels are removed there is one screw at about 11 o'clock and then the other is perpendicular to the ground up and behind the first (can't be easily seen). I hope these pictures help.
http://www.kofira.com/jeep/SilverStars/index.html
You'd get more answers if it was in the OEM tech, not user support. This section is for questions relating to the use of the boards not tech. HTH.
Person's who have not yet confirmed their forum account are restricted to posting in this forum only.
Fourtayfour, you may want to check your email for a registration confirmation email that has a link that you MUST click on to enable the full forum functionality of a NAXJA guest.
Skorpyo
