afd516
- Fort Worth, Tx
So I got up at 6am and got ready for a day of wheelin. We wheeled from about 7am to 12pm. We decided it was time to leave about 11am. So we started to head out and we could either turn around and travel 20-30 more min or go up this pretty narly trail and hit the road in about 10 min. Take a guess which option I chose. So, I clear the last rock ledge at the top after my buddies were moving rocks and guiding me yadda yadda yadda when POP what the hell was that!? I got out and looked and did not see any thing so we climed back in to hit the road and this time even a louder pop.
Broken passenger side front dana 30 non disco u-joint. I got my tools out pulled the shaft and put it pack together. We hit the road.
This was the first time that I have broke a u-joint. When pulling the broken axle what it be a good idea to pull the opposite side also? Would it make a difference? I was just thinking about the fluid that may or may not come out of the seal that is no longer plugged w/an axle shaft and its effect on a ring and pinion if the opposite axle is left in place sloshing the gear fluid out the seal.
It always happens when you are fixin to leave.
