Been a long time.. had an FZJ80 for a bit, that I lifted... etc... Now we have bought a Forester(with an LSD
) I will be tossing a small lift and 28" Geolanders on it.
The Jeep got brought back down to NC, it had been sitting for about 6 months at my pops place in VA. I'm Bringing Sexy Back...
1. FIND this stupid VACUUM LEAK..... my HVAC blend door operates off of Vacuum, and I barely have heat/air conditioning because under throttle, vacuum diminishes and my blend door opens up to allow fresh air in... and not to mention, the door controlling where the air is directed closes up too.....
2. Im about to order a new Exhaust Manifold, FINALLY.. was going to order an aftermarket header, but people seem to have a lot of problems with fitment(on Jeep 4.0 Inline 6, the Intake and the Exhaust manifold are on the same side..) SOO.. it seems that people have had Good luck with Dorman OE replacement headers. Im going to give it a shot, especially because everything I have read suggests that OEM Exhaust manifolds perform as well, if not better, than most aftermarket. I can order one on Amazon for about $145.00, which is a screaming deal.
3. New Motor Mounts... yea, ive been through three sets of these...... This time, I will not be using OEM mounts..... Brown Dog mounts will be used, check them out... they are SUPER BEEF... they use control arm bushings instead of the flimsy motor mount style used in OEM applications.
http://browndogindustries.com/
4. I need a WELDER!!! I need someone to weld some Sway bar mounts on my front axle, and I need someone to weld some New shock mounts on to the rear axle. Lastly, with the welding right now... I need to have someone weld up my new door hinges(so my doors are removable).
5. Tires... I will be ordering 315/75R16 tires. Im looking at Firestone Destination M/T's, Goodyear Duratracs, and BF-Goodrich KM2's..... I have destinations now, and they have lasted 6 years and 75,000+ miles, hard, grueling miles, full of rocks, mud, etc... to boot, they are much cheaper than the BFG. The Goodyear Duratrac is the cheapest, and I had them on my land cruiser and loved them.
6. Shocks.... this is simple, Bilstein 5100's will be going on it......I can measure for them until I get the 35"s mounted because I have to flex it out and get all my clearances taken care of, but it will be simple.....
7. New Carpet, stockinteriors.com most likely
8. Headliner with a soundbar added right behind driver/passenger for when the doors are off
9. I NEED A HEATSHIELD for under the rear seat... mine has melted...
10. I need a rear seat... LOL
I have had this Jeep for nearly ten years now... Looking back. it's been a labor of love
