supark
- San Francisco
Brand spankin new member with my recently purchased 96 XJ 4.0
I was shopping for a car that would offer: 4wd, bulletproof reliability, cheap and easy to repair, able to tow at least 3500 lbs, under $5k, and as a hopeful feature - would not be a total dog to look at. After asking around bimmerforums, I learned about the venerable XJ 4.0 Cherokee and that it would meet all of my needs while also looking pretty dapper at the same time.
Just bought a 1996 Cherokee XJ in Country trim (all power locks and doors), 4x4, factory tow package, with 119k miles and the most hideous wheels I've ever seen. Body is pretty straight with the except of a light wide dent on the rear passenger door and a love tap on the rear bumper. Paid $2800 private party, and I think I got a decent deal - not smokin hot, but better than average given the mileage and condition - it is very clean. I also just noticed that it has an immobilizer installed with a digital key under the dash - pretty sweet and something I was planning on getting anyways given SF's petty crime rate.
Planning on doing the following preventative maintenance and cosmetic mods to start out with - anything else you guys think I should do? Also what's the best place to get filters, parts, etc?
As you can see it is pretty damn clean. The wheels as already mentioned are XXXXing hideous, so need to get maybe some later model steelies stat.
- automatic transmission fluid/filter change
- run some chevron techron injector cleaner through a tank of gas (doing it now)
- install B&M auxiliary trans cooler
- fuel filter change
- run a quart of automatic trans fluid in the engine for 10-20 miles and then change oil and filter
- get some rustoleum bed liner paint and do the front and rear bare metal fenders in black (after I pound out the love tap in the rear)
- Radiator flush with prestone kit
- When I initially took it for a test drive, there was a very slight knock at idle and a little stumble. Nothing severe and honestly not as bad as some bmw I6s I've owned, but after I drove it about 55-60 miles back home I noticed that the knock had gotten louder and the idle stumble slightly worse. It sounds like the knocking is coming from one of the middle or rear cylinders - the best I could describe it is kinda like thicker dishes lightly rattling against each other. Is there an inherent knock sound to these 4.0 I6 HO engines? Or am I looking at something perhaps serious? It's weird though because I can hardly hear it when I first start the car.
- Steering has a fair bit of slop and seems to pull a little to the left with the steering wheel perfectly centered. I'm guessing tie rod ends and other suspension bits would benefit from a freshening - what's the best way to test for wear on these?
- Power steering fluid is low - not surprised that there's most likely a leak, I'm guessing it's at a hose clamp beneath the reservoir because when I did the underbody check I saw fluid only on the front of the engine and the valve cover gasket didn't seem too bad.
