Double Down
- Cincinnati, Ohio
Quick question or if you can direct me somewhere. When I originally did my lift I put on older YJ? brakes lines to make them longer obviously, but as we found out recently, the size of my lift is bigger than what we thought. So when I am at full flex, the brake lines seem to be pretty tight (should they be tight or loose when flexed?). What lines should I be using for a 97XJ with about 6" of lift?
Also, for the rear, that line that runs from my axle up to the frame, vacuum line? That is pretty tight also, where can I pick up more of that or longer version?
Thanks,
Chris
Thanks,
Chris
