99NCXJ
- Belmont, NC
I'm working on a 91 cherokee that was brought to me with no working brakes. The pedal just went strait to the floor and would only stop the truck if it was going very slow. I have bled the lines but didn't help. I also swapped out the master cylinder but also didn't help. Then i thought, maybe the proportion valve was bad or clogged. I swaped it out and still no help. There are no leaks anywhere that i can see and really don't think there is any air still in the lines.
When the vehichle isn't running the brakes feel just ok, but once you fire it up the pedal goes to the floor. So I unhooked the vac line from the intake to the booster and its just like as if the motor isn't running, ok but not great.
anyone know what is going on? is the booster probably bad? I've just never heard of them going out before, but i guess its possible.
