C Christopher NAXJA Forum User Location Bakersfield, CA Dec 9, 2003 #1 Does anyone know if the Brake Booster Rod is removable? If so how and can a '90 ABS rod be put on a '96 booster?
R rsalemi NAXJA Forum User Dec 9, 2003 #2 The rod is not easily removed - brake rebuilder can do it. The rod on a 95 or 96 can be used by opening up the diameter slightly for the pivot bolt (use grinder or dremel)
