tdicola
- Seattle, WA
Hi all, I just bought a '99 Cherokee with 150k miles and noticed a squealing sound from the front wheels at low speed. The squeal comes on after the car has warmed up and driven for a while. It will only come on after braking but will keep squealing afterwards regardless of the brakes being applied or not. A friend and I took a closer look and can see the anti rattle clips on the brake pads are dragging on the edge of the rotors. When we hold the clip up and move the wheel a bit the squealing goes away.
Here's a picture:
Has anyone experienced this problem and found any good solution? Looking at the factory service manual for a 99 XJ I don't see any anti rattle clips mentioned (although it looks like older models had them). I'm thinking I should just rip the clips off and see how things go as the squealing is pretty annoying right now.
As a side note do you have to take the whole caliper off to get these clips off? I'm thinking I'll just get some wire cutter and snip them in half to save the trouble.
Here's a picture:
