bradleyheathhays
- Lexington, KY
Just finishing up this Bondorific patch job on my rocker panel (and opposite side rear panel section) and need advice
on how to finish things up. I believe I've read that bondo can be spread as thin as you want as long as it has good
mechanical adhesion, but I'm wondering as I do these last steps if I might could use something else meant for filing
in more nuanced scratches and little valleys.
Basically I've got both panels shaped about like I want (exposing some sheet metal along the way) and now I just
need to fill in the 36 grit sanding marks on the bondo, cover the exposed aluminum, sand up to 800? grit, then go at it
with color coats and then clear.
2 questions are...
- What should I use to fill in the bondo scratches and cover the exposed aluminum? body panels?...possibly some kind
of high build primer?
- What's the minimum grit you need to sand (the primer?) up to before applying the color and clear coats? I've been
told anywhere between 400-800. For the bonding between the color and clear coats I'll be timing them to take advantage
of chemical adhesion.
note: Since this picture was taken I've added another skim coat of bondo to fill in those small bondo divots, but I should
have those same 36 grit scratches after I sand it back down again.
2 questions are...
