BRIANHO13
<- Yum Chocolate
- Spring, TX
vetteboy said:
How did you get the creeper to levitate?
vetteboy said:
XJ_ranger said:so all you really have is cut out rockers, then supports to them that eat clearance? all so you can mount a cage?
hmmm...
seems like a lot of work for negative clearance gain over just cutting out the rockers, and mounting the cage to the frame rail...
though - I wish that i had re-enforced my rock rail replacements, as they are about 1/2" higher than they were when i built them, and my door doesnt like that all so much...
Kaczman said:Jon with an H is for Tards.
I made the structure out of 3/16 plate and skinned it with 3/8's UHMH.
My design needs some serious improvements. I was concerned about using the stock A, B, and C pillars as the structure for the boatsides. The B pillars are buckling from every direct impact in the area.
This off-season I plan on cutting the existing boatsides and incorporating them into the cage and sub-frame. The 3/16's steel and 3/8's poly seems to be a good combination so I'll stick with it. I'm not as anorexic as Dave and Paul.
-Jon
hmmm...
I wish I had a cage to support mine off of, the way that IntreppidXJ did his -
http://www.myxj.net/tech/rockers/
BRIANHO13 said:How did you get the creeper to levitate?
now THAT sounds fun!! :laugh3:Lunatic728 said:be very carefull moving it. It can slide for a long ways with very little effort on a concrete floor.
___________________________________________
www.pa-wheeling.com
steagall9301 said:now THAT sounds fun!! :laugh3:
Utah is all based on the frame height, but you may have to put some funky mud flaps on the front wheels.neonrog said:OK, I've read this thread, again, and I'm considering boatsides for a different vehicle. My only real question is, how high can I go up the side of a street legal registered vehicle? I live in Utah, but just wondering if this is an issue in other states as well. Thanks!
Scrappy said:I would use 5"x1" .120" wall square tubing so I get the super high clearance.
brent said:Utah is all based on the frame height, but you may have to put some funky mud flaps on the front wheels.
Scrappy said:So any new ideas on this? I just started a new cage that has huge boatsides in it. What kind of hieght have some of you raised your rockers to? I did this one just over 10" from the bottom of the stock rocker. Looks crazy to me, but will work well.
Also, what are some of you doing with the wheel tubs?
Jump This said:Most of us don't wine about a rock or two destroying out rocker panels...
:looser:
Your contribution to resurrect this thread is about as useless as mine...thebluebuffalo said:true that
(Re: Vetteboy79's rig)
You dont need those frame supports right? So why have them?
