kind of stumped here, and not sure where else to try
99 xj 4.0 auto.
while driving during hard acceleration, i blow the under hood fuse for coil and pcm, fuse number 21
it also does it while not driving in neutral if i put the accel pedal to the floor.
when it blows the fuse i do get a 1389 code, no ASD relay output at PCM, i dont believe the code is the reason for bliowing the fuse, but rather the code that is generated when this fuse blows. after replacing the fuse the code goes away with only a few restarts
i have tried replacing coil, ASD relay, fuel relay, the ignition key switch, CPS, TPS, and cleaned grounds to the coil and replaced the negative terminal to the battery.
i have a 97 i have been using to swap parts back and forth, except the coil, which i had to buy
the first time it did this was when i had my rear shocks replaced, and went from 235 to 31" tires. not that i think this is the culprit, but thought i would mention it.
thanks in advance for any help.
RD
99 xj 4.0 auto.
RD
