Blower Motor Speed Switch
Magus2727
Draper, UT
My blower speed switch broke (only does the lowest speed), and need to get a replacement.
Are the parts on rockauto.com in the following path the right parts?
1995 JEEP CHEROKEE 4.0L L6 : Electrical-Switch & Relay : Blower Switch
Like: http://www.rockauto.com/catalog/moreinfo.php?pk=942301
Does the black portion of the switch remove easily and install on this new switch?
Edit: I have not taken it out yet, but the black "rocker" switch may also have broken, any one know where I can get the combination of the black "rocker" switch and the blower switch it self?
Thanks!
The rocker switch is wired to the blower motor resistor, if it is broken chances are it is stuck on the speed it broke at. Take it apart and you'll see what failed.
Yes, that looks like the right part. I changed one a couple of weeks ago and it was pretty easy. If I recall correctly there are a couple of small screw/bolts that connect the switch back to the back of the heater control which then re-engages the switch to the front mounted rotator.
Here is another source: http://www.jeep4x4center.com/heater-blower-motor-switch-83502719.html
More expensive than Rock Auto but really good customer service.
Thanks!
