rokn92xj
- harrisonburg
for a couple inches of cheap lift should i get blocks or aal????
Fixed it for ya.Eagle said:Full-Length Aal.
Yep. Blocks are horrible. Don't do blocks!!Eagle said:Aal.
Yucca-Man said:Fixed it for ya.Originally Posted by Eagle
Full-Length Aal.
rokn92xj said:why are blocks so bad??
ChuckD said:Blocks are not that bad. Search and you can find some go info. The main reason that blocks are bad is due to the greater leverage they place on the leaf pack. This leads to spring wrap and bowing of your springs.
Search and you will find on how to use them properly.
maineiac said:i have done it all so far aal was a stiff ride , i broke 2 blocks a steel one and an aluminum one ,now i have RE rear springs and all i can say is save for the springs you will be much happier
