Jonner
- Charlotte, NC
1998 Jeep Cherokee Sport
207K
4.0L / AW4
Dana 30 / Chrysler 8.25
Aside from the engine, the Jeep needs:
-New ring and pinion for the 8.25 (grinds on deceleration)
-New radiator (leaks)
Story goes like this...
Well, we had -30 degree temperatures yesterday and I was driving home from work at midnight. I started seeing steam pouring out of the drivers side front of the hood as I was about 2 miles from home. Check engine light went on, voltage meter went to zero, throttle felt like it was pushing the car forward more than usual or I had less brake vacuum boost (I think both). I came to an offramp close to home and attempted to put the rig in park. The engine shot up to 4000 RPMs so I shut it off.
I let it sit for a minute and opened the hood to inspect the damage. Everything was covered with coolant, and I had trouble telling where it originated. The coolant container was full to the top with milky coolant. The oil filler cap had whitish snot plastered all over it. I was able to restart the engine to limp it home. It was running rough but there were no nasty metallic sounds coming from the engine. I probably blew a head gasket, and might have blown a freeze plug. At the very least, the engine will need a new head gasket, new freeze plugs, and new gaskets all around (front and rear oil seals, etc).
I'm looking at replacing/rebuilding the engine. The motor could still be good, but it'll be a day before I can get it into the garage and it's still -10 degrees outside.
From reading reviews all over the internet, I want to stay away from a remanufactured engine (no ATK or Jasper). I think my best bet is to source a junkyard engine somewhere in Ohio, or pull the motor and take it to a trusted engine shop. I have no cash, just credit, so I'm trying to keep costs down but would like to get another 40,000 miles out of this rig.
Option A - Cheaper, quicker turnaround
So I'm looking for advice on sourcing a reliable 4.0L that'll work with minimal fuss in my '98. Right now I'm using car-part.com and Craigslist to find motors in Ohio. What years will fit without fuss? 96, 97, and 98???
Option B - More expensive, slower, but should be more reliable
I'd need to find an engine rebuilder I could trust close to central Ohio. I'm undecided about getting into every part's details, and would prefer to leave that up to the rebuilder but don't want to get screwed not knowing what to look for inspecting after the rebuilder is done with it. Any suggestions on trusted Jeep engine builders near central Ohio???
The bottom line is I need an engine on a budget and need to stay under $1500 for the engine. I still need to buy an engine hoist and engine stand, and some smaller specialty tools for the project. Anyone near central Ohio that has local advice? Or, anyone been through something similar and lived to tell the tale?
