hubs97xj
- Fort Wayne, IN
Read this thread; should help you with the adjustment.
http://www.naxja.org/forum/showthread.php?t=1086833
YES!! I got it open! Someone on another forum suggested to lift the handle and press DOWN very hard in order to fully close the liftgate. The handle apparently doesn't work if it's only partly latched. I pressed down hard, then I'd turn the key again, and try to open it. I did this a couple of times, and it eventually worked! By pressing down, I somehow got the latch to fully seal, and then pulling up on the handle disengaged it. It seems my latch now sticks, maybe something got knocked out of whack when it jammed, but I'll take it.
Now, I can focus on why I was using the liftgate in the first place! To install the 4 OEM Ecco wheels I just picked up for $150. They have 235's on them. They are significantly more larger than the 225's than I was expecting. 2 tires are toast, and the other two are 7/32 and 9/32. These Ecco's will be a major improvement from my rusted and primered Steelies that will now be replaced.
This happened to me once. After trying everything I could think of, I concluded that I did not have the special tools or expertise to handle this advanced repair so I took it to a qualified mechanic.
I got an estimate from the dealer and a local shop. Both appeared to be unreasonably expensive. I took it back home and began to research my options. Becareful, there are a lot of self proclaimed experts on the Internet with good intentions, but they simply don't understand the difficulty of this advanced repair.
I eventually succeeded with this repair, it did involve taking a 6 month leave from my "top 5%" career. Start by jacking up the front end, that will help with your leverage angles. Then remove the oil filter adapter and the O2 sensor to reduce the pressure on the hatch, you may need to pull the heater control light bulbs as this will reduce inside cabin temperatures.
Next, be sure your hatch is unlocked. Depress the hatch release button and pull the hatch toward you. (Be careful not to rock the XJ offthe jackstands)
Note: that depending on your blanket, this may require freakishly strong, blue collar grip and strength. You may need to employ a small team of experienced jeep mechanics to get this done.
Most XJ owners would typically consider this to be an advanced, dealer only repair item. Though the costs may be prohibitive and may just warrant parting out your XJ.
You should really charge for this kind of advice! Totally plausible and very well explained. LOLarty:
Kind of like I said on post 3? Push the hatch closed push the button and pull on it... Thought so...
great wheel choice, i run eccos on my MJ:
bimmerjeeper has no chance in hell removing the rear bumper, thats for sure...
No, if you squirt clorinated degreaser down the intake it will kill the O2 Sensors.Ahh, Is that why they sell non-chlorinated engine de-greaser?
That blanket must be the 1% as it owns you
I fixed it for you.Help blankie in door?.... this is hilarious!
Mark my words--this thread won't last nine pages!
