- Colorado
Sucky
I've run foa before. I don't recommend them at all. I would rather spend money on used fox, king, saw, etc. Either way you will get familiar with the internals and workings of a rebuildable shock. Foa out of probable frustration and the used shocks out of the regular rebuild process.Did you see how I cut a pocket and welded channel to lower shock mounting point down beside control arm bracket.
On my dana 30 I'm building I going to build a bracket off the side of the control arm bracket
Bracket will have adjustment to tun my current 10" shocks and I'll be able to do 12"
I'm sitting at just shy of 2" of lift have the lower mount lowerd quite about.
I did notice the foa shocks run long. Othere than that all I know is the are far less expensive than fox I've also seen a mixed bag of review's from haters to lovers. For 150 bucks they're alot of shock.
They do not come charged though. The need about 150 shot of nitrogen ounce recieved
Yeah there's always of both sides of the foa debate. I've not bought any yet so I not sure what side that puts me on.
I like I can get 7/8" shafts without resivor.
I've been watching Ebay for used 12"
Lol true.
I have just fox 2.0 ifp right now.
I'd like to get into a tunable shock nw that fox has bit me with they're low end until
Idk man... they look kinda cheesy imo.. no valving specs to be found either?
Not saying Billies are the best, but imo are better then the average multi branded white tubes and I’d argue the best shock for under $100ea
Why are you on the mono max wagon? I thought you were pretty stoked with your Goadiator Foxs?
