bradleyheathhays
- Lexington, KY
What's the best non-spicer u-joint I can get for my 96 XJ front axles that has zerk fittings?
When you install the greasable U-joint, place the
yokes so the zerk fitting is under compression
when the driveshaft is under power. (As opposed
to being under tension.)
This will make the U-joint much less likely to fail.
