hit up jeeperjohn hes got awsome prices and he is super good
Plus, he'll touch you in your no no parts for no additional cost.![]()
They're the trail rails made by rockratz and they bolt straight to your rocker panels and are pretty much flush with the rockers. I love them. You should be able to find them on rockratz.com
I know you are buying them and not building but....
The best XJ rails are simply a 2x6 .188 wall rectangular tube welded in directly in the space the rocker used to take up. Very easy to do but 20' of welding. You don't lose another 2" of clearance, you gain 1" more of clearance and make the unibody stronger at the same time.
There are several threads here describing how so find a friend that can weld and get it done, you can do all the prep and it can be done in 4 hours if you spend the time actually working and not just drinking....
Anything that rely's on using the pinch seam as a mounting point is just bad thinking.
My grandpa had some sitting in his garage that he never put on his jeep and when i bought it from him he gave them too me. They have performed great i have hit them hard many times. They're the trail rails made by rockratz and they bolt straight to your rocker panels and are pretty much flush with the rockers. I love them. You should be able to find them on rockratz.com
