Jeepin_rebel
- Ft riley Ks
Im goin up in lift from 3 up to 4.5 er so. Where is the best place to get new longer brake lines for the lowest price. Thanks for the help.
Ryan
Ryan
Is that stock YJ? Never really thought about bendin the hard line. How much longer will i need over stock for 4.5-5 inch lift?GI-John said:buy a set off of a 943 YJ Wrangler 12-15 bucks each
3-4" longer, and are DOT certified.
If you haven't already, straighten out the hard line for an extra inch or two
Jeepin_rebel said:Thats some good stuff. Will save me a good bit.......now what about a track bar bracket? Easy to fab or should i order one.
I sent you a PM ......my wife is in Denver right now.Yucca-Man said:1" Motor Mounts usually go hand-in-hand with the SWB guys (TJ/YJ) when they do a 1" body lift since it helps keep the front of the engine in line with the radiator shroud and all that. I don't know that anyone has done a motor mount lift on an XJ...
If you want to save $30 and can swing through Colorado when you get back you can have my t-case drop; call it a 6er of Fat Tire?
