Bed swap questions and advice
Johnnie Walker
Piece of Fish!
WA state
My MJ currently has a utility bed on it (pics in my build thread). And it is partially welded to the frame.
I noticed that the from the factory the fuel tank attaches to the bed. Since the utility bed will most likely be removed at a friend's shop, I was thinking about using some strips of steel/other material across the frame for the tank to mount to.
Any thoughts, concerns, constructive criticism?
actually it's attached to the frame and the bed. The straps have pins that fit into slots in the frame side.
If you slap some supports across the frame to attach the threaded rods to you should be fie.
I guess I should have added that, I knew that the driver side mounted to the frame, and the middle to the bed. Thank you for clarifying it though. I figured it shouldn't be too hard once I pull the utility bed.
