LOCKED UP
- Baton Rouge, LA
Sorry I was hopped up on Nyquil...
Here's what I know:
...MM hub conversion. The instructions say nothing about any difference from 98-00. This leads me to believe that knuckles are the same for at least 95+ (when the break is in the kits which corresponds with the change in u-joints), though I suspect the knuckles are the same from 93-01.....
93 ZJ hubs I have are the same depth to mounting surface as the 98 XJ hubs I have. My stock 00 XJ hubs sit "in" about 1/8 inch.
A while back I swapped on my 98 HP d30, using the 00 rotors. Seemed to have no problem at all, but perhaps my rotors were sitting "out" 1/8" due to this difference? I had removed the dust shield so it would have been <1/8".
Either way, I had no apparent problems.
Now:
I have 93 ZJ Knuckles (which should be the exact same as 98 XJ or 00 XJ knuckles... right?) on my 98 HP XJ axle. The rotors on there are from a 00 XJ and the hubs are brand x from pepboys. I believe they were the same "depth" as the 00 hubs....
Since I now have hubs similar to the 00 hubs & am using the 00 rotors it should be lined up straight again with the exception of no dust shields.... right?
For the hub conversion I'm planning, the rotors I've found are .125" thick & cast. Instructions call for .25" thick cast. Local 4x4 shop has done several of the conversions and they use the .125" cast rotors with "no problems". So does this mean that all the conversions thay have done cause the rotor to be off by .125"? Hell, one guy I know got the stock composites machined and ran them far a few years before they broke....
So my questions are now:
1. Is a 93 ZJ knuckle is the same as a 95-01 XJ knuckle?
2. If the rotor isn't centered between the brake pads how do I know? How uncentered can the rotor be and still be OK?
Here's what I know:
Now:
