CharlesS
- Quezon Province, Philippines
The dirty battery connections would definitely have an impact on if or how well the system would charge/operate; although by now your battery would certainly need to be replaced due to sulfication even if the alternator tests good.
The alternator does not have a voltage regulator persay; the PCM controls the rate of charge thru the field source and sensor wiring that is why I suggested earlier to check those connections.
