battery group interchangeability?
ROADLESS said:
Just put an Optima D34 in our 89, has lotta room.
Thanks ... so you had plenty of headroom over the battery? The reason I'm concerned is that I have marine-style battery terminals, which add another 5/8" of height to the connection.
Plenty of room. If you want to double check, put a block of styrofoam or something the same size (as the battery you want), close your hood and see. BTW how far are you from Kalispell?
I had to lower my tray a little, there is a spacer under it.
