JeepNovice
- Gardner
Rear line that connects to axle . Yea I ordered from dealer.
Your name isn't Mary Anderson is it? I used to go with a gal from Boston in 1965. :kissyou:
Nope! I was not even around then! :exclamati
I'm having a shitty time getting that rusted bolt out to remove brake line. I broke off line to have better access but think it's so corroded that it has shrunk! What size wrench am i supposed to use, i thought it was a 10mm and that does not work at all, too big. I been trying to use a socket wrench 9mm and that's too small. Any suggestions?
Flare nut
Ok so I used a 3/8 flare wrench it doesn't grab to it. So I'm using a 3/8 socket which is the only thing that grabs to it and nothing! Yes I'm having fun but I ll have more fun if I could get that off! Do I have to disconnect the plastic line that goes to axle for this?
Vice grips or a six inch pipe wrench.
