GrimmJeeper
- Gardena, CA
that's not the correct fitting, the o-ring seals at the base of the hex on the earls fitting, there is no flare or tube that protrudes into the transmission - it's just a threaded hole.
So I finally got around to finishing up this job and it was a little different than Grimm's so I figured I'd post up the finished product. Ran the lines to a B&M cooler mounted in front of the radiator instead to the rear window like the original post and a few different parts were used. The main difference is a 90* fitting won't work on the feed line coming out of the AW-4 because the dipstick is in the way. I used a 45* fitting to get around this.
For the cooler I ran an Auto meter 4357 trans temp gauge on the feed line right before the cooler. For the sender I used an Earl's bulkhead tee to for the 1/8" NPT temp sender.
Since the sender won''t ground off of the tee because of the rubber lines, I used a 3/8" ring terminal and some 5/16" washers as spacer in between the sender and the tee then grounded to the frame.
Here is a complete parts list, all fittings are from Earl's Store #1(thanks Tom):
2x 9919DFH (14mm to -6 adapter)
2x 176106 n(-6 Viton o-rings)
1x 709167 (-6 90* hose end)
1x 704667 (-6 45* hose end)
3x 165006 (-6 to 3/8" hard line tubing adapter - male)
1x 165106 (-6 to 3/8" hard line tubing adapter - female)
4x 700167 (-6 straight hose end)
1x 980406-1 (bulkhead tee 1/8" female)
Bumping this thread for feedback from the guys that have done this mod. Especially with AN fittings. Y'all got any pics of your setups?
There's a new item out, Parker 68H8-6-M114 Port Adapter, that will screw into the trans ports and has a barb type connector on the end.I'm looking to put barbed fittings into the transmission so I can run hose directly off of the trans without using the quick disconnects, anyone know of a part number? I've been searching for the last hour and all I can find is threads on cutting the stock lines with a tube cutter and attaching the hose there. That is NOT what I want to do. I want to replace the fittings in the transmission.
This is an old post, but I'm hoping this info will help someone in the future...
I want one but the listed part number doesn't show up when Goggled.
Do you have a link to a supplier?
