Ball Joints on Waggy Axle???
Heep
Nebraska
I tried a rented ball joint press and even used my impact and these fkr's still wont budge. This is a junkyard axle but wow, I even tried the BFH method and nothing. Im going the right way too, any suggestions?They are soakin in PB blaster for the night
You know there's a snap ring on the bottom one, right? Other than that... PB Blaster and BFH. If you're desperate... I know my local napa will change them out... you might wanna try yours.
Billy
Try a little heat. Even one of those little propane jobbies that go on the disposable tanks will work. A little expansion will break the rust hold.
I have also tapped around it with a hammer when the press is still on. Use a big hammer on one side (held in place) and hit with a smaller hammer on the other.
Good luck.
