HeyAwesomePeople
- Las Vegas
Hey jeepers. This is going to be a long one. I have two issues. My jeep tried to run into a pole today with it's DW so I need all the advice I can get.
First issue: Death Wobble!!!
I have replaced the track bar, drag link, and tie rod ends (1AAuto). I have gotten my car aligned (twice). My track bar is stock and I do have a 4 inch lift, so my axle isn't centered perfectly. I torqued the tie rod ends to 55 ft-lbs. Nothing feels loose that I can grab and shake.
The death wobble began several months ago after a trail ride but only at high speeds. I ignored it for a while. Just a week ago I used to get the death wobble above 65mph. I figured now it's time to replace some things. I did the track bar one week and it had no change, it still death wobbled at 65mph. The next week I replaced the drag link and tie rod ends. I immediately went and got an alignment - and what do you know??? Now I get death wobble at 45mph+.
Every bump I go over it feels like I'm going to go into death wobble when doing more than 30mph. Over 45 mph, and bumps/potholes/manholes send me into the death wobble. Did me installing tie rods and getting an alignment mess it up even more?? My alignment also isn't holding. They say they get it perfect and I see the numbers the computer says they did. But one day later I come back between I'm out of alignment again and they ask me if I changed anything!? (I didn't).
I'm at a loss. My daily driver is parked right now. If I can't find a solution soon I am going to have to take it to Adam's Driveline (a 4x4 repair shop in Vegas). I don't really want to have to do that since the tow will cost a chunk of money and the diagnoses/repair will cost money too. Budget is tight though, as I'm still in high school.
Any help in this area would be nice! Thank you!
Second issue: Knocking Noises, Banging noises from Drivers side
I also have a knock, it seems to be coming from the drivers side. When shifting from 1-2 (Manual) or going over bumps like driveways and speed bumps, I get banging I can feel under the floorboard and hear it audibly too. It's feels like something is about to break off. It doesn't seem to occur at higher speeds. I cannot for the life of me figure it out.
I did notice though that my drivers side coil was missing a coil retainer. I am ordering new coil retainers now as well as coil isolators (why not?). I noticed too that with my front end lifted up by the frame, I am able to punch my drivers side coils and get knocking/clanging noises. I can also shift it around. I cannot do this to my passenger side coil. Should I be getting new coils? Video of coils
The ball joints also don't have any play (tested by jacking up with tires and grabbing them 12 and 6 and shaking). I figured maybe the shocks could be causing it (shock bushings were all bad), but I still get noises with both shocks removed. Sway bar link bushings are also new and tight, as well as the sway bar bushings themselves.
I was driving at about 30 mph today (slowly because I almost crashed from the death wobble) and I hit a small bump. It literally sounded like something fell off of my jeep (nothing did that I can see).
so yeah. death wobble and terrible noises from my front end. Any advice on what to do here? I have ordered an adjustable track bar from rusty's as well as shock bushings (to install Bilstein 5100's) and a new steering dampener (mine was old and leaking fluid. I know it isn't a reliable fix for DW, but I figured they're cheap and I need a new one anyway).
Here are some pictures of under my jeep.
Thanks for any suggestions.
(I have cross-posted this with Reddit, Jeep Forums, Cherokee forums, and just to explain why you might be seeing this post a second time)
