Bad vibrations and noise after replacing unit bearing.
jack it up, remove the wheel, and free spin it by hand. Would be good idea to remove caliper so as not to have any possibility of rotor-pad drag
Did as suggested and it spun freely. I also did the 12/6 and 3/9 tests with the wheels on, and there was no movement. I guess that leaves the U-Joints and ball joints.
I also took off the front DS and still had the vibration
think I found the problem passengers side u-joint
I also think I need a new outer shaft on that side the yokes seem bent.
