Bad TPS?
Mike L
Anaheim, CA
I went out to drive my Jeep earlier and it wouldn't start. It would turn over but not actually start. My rig is a 96/4.0/AW4/231. I did the turn key code thing and came up with code 24. It says to check the TPS and the wiring. I little while later the Jeep started up and I took it for a drive around the block. The idle was really rough and it stalled. I coasted to a stop and it started right up again. The idle is always very rough. I assume a new TPS would solve this? Is there an easy way to test this thing or adjust it? Thanks.
-Mike
