Backfiring through intake, loud sucking sound from intake
Post up a photo(s) of the actual vacuum lines, as it sounds from your description that MAP sensor might not connected to the proper vacuum line?
Issue completely died away after repairing the ccv lines, however the tranny noise has only gotten worse. Never noticed the tranny noise until i went doorless, then i could hear the screaching easily.. The clutch is about out on the jeep i know, and my best guess is the throw out bearing is shot, would be about right timing with the the clutch being as low as it is. Plans are to drive it as it is until i find a donor for my 4.0/4wd swap. Figure its pretty useless to put work into a tranny i wont be using soon, I just hope it makes it that long lol
