jgl4wdccherokee
- Tulsa, OK
Here is a list of what I am trying to get rid of.
-GM 14 bolt rear end 3:73 "Diff looks like an Eaton Posi". 150.00
-GM Dana 44 Passenger diff flat top knuckles "It is missing the long+short shaft on the long shaft side 4:10 standard rotation open carrier. 200.00
-Brand new set of 8 lug Dana 44 rotors. 110.00
-Ford high pinion Dana 44 Drivers diff pretty much just the housing is all that is worth using but with the parts from the GM 44 you could build a pretty decent set up. 150.00
-Long and short axle shafts and stub shafts out of a '78 ford Dana 44 front end I think they are 30 spline inners. 100.00
-Medford Tools mandrel bender with 1 3/4 inch die and degree pointer. This has never been used I put it together but have not ever tightend down the bolts I have all the instructions. Bender was 349.00 and Die was 200.00 I would like to get this back.
-Medford Tools notcher same situation never used this cost me 179.00 and 10.00 for 1 3/4 hole saw that has never been used either. I would like 179.00 and you can have the saw I was told it will last long enough to do an entire cage.
-Set of 8 lug steel chrome wheels 16.5 x 10 with bald 33 x 12.5 tires. 125.00
-18 foot tandem axle flat bed has 15 feet of deck space storage box on front and is around 7 feet wide it has electric brakes and ramps are included. This is a homemade trailer but it pulls really nice, it is heavy but I have had no problems towing it. It needs new tires and some paint if you care about that, I used it to tow my Cherokee with 32 x 11.5's and my SCCA club rally car all over the Northwest and back and forth between Washington and Colorado. 1200.00
All prices do not include shipping and are negotiable I will possibly deliver depending on your location, I am just outside of Montrose, CO. I can send pics please email all inquiries to [email protected]
