Skaven
- Ontario, Canada
Hey guys..I have access to the axles out of a 1994 Dodge Ram 3500 HD. The front is a Dana60 and the rear is a Dana80 from what i can find on google. correct me if im work. As far as the rear axle goes I think that will be a fairly easy swap..just cut off and weld my spring perches and shock mounts where I need them. But as for the front axle how difficult is this swap? Im fairly compentent with a welder and have friends who are journeymen would could help me out. Im sure someone else here has done this swap and any insight would be greatly appreaiated..btw if your wonder why the big axles im also going stright from stock most likely the 6.5' RC long arm lift and 35's and what axles that would hold up to the big tires with lockers. Also if theres a write up that I somehow missed please let me know
Thanks guys
