Are you talking about the ones on the axle mounts?
The one on the diff is fairly easy but you have to be gentle with the other one as you can bend the bracket.
I have my best success using an air hammer and blunt chisel end. Starting with the side with the flare, give several bursts around the perimeter of the bushing sleeve and generally they walk right out.
