axle seal help?
lil_red_wagon
hot springs ar
have a d35 rear and im trying to replace the axle seal. the one in it has NOK 42914 on the seal but i cant seem to find a cross over. the one i did find gave me a seal # of Timken p/n: 8660S but if i search that one and get the specs on it of:
Wheel Seal I.D. : 1.399"
Wheel Seal O.D. : 2.296"
Wheel Seal Width : .469"
and a p/n: 13990 CR with the specs of:
Wheel Seal Width : .5"
but if i do a search on auto zone or advanced web site their specs on their wheel seals and it lists the timken 8660S.
napas web site dont have a cross reference to the nok number. has anyone changed this seal and remember the part number.
btw i dont have a dial caliper to measure the seal and axle.
i did more research and found on napas web site they list a even diff one. with the specs of:
Wheel Seal I.D. : 1.688"
Wheel Seal O.D. : 2.556"
Wheel Seal Width : .375"
has anyone replaced this seal and know the right part number?
Here are some listings from rockauto.com:
TIMKEN Part # 8660S
RWD; Dana/Spicer 35 Axle; Rear
$1.61$0.00$1.61
BCA/NATIONAL Part # 8660S
{Oil Seal / Nitrile / Shaft Size=1.399" Housing Bore=2.292" Outer Diameter=2.296" Width=0.46"}
Rear Wheel; Spicer 35C
$2.35$0.00$2.35
BCA/NATIONAL Part # 6815
{Oil Seal / Nitrile / Shaft Size=1.94" Housing Bore=2.5" Outer Diameter=2.505" Width=0.25"; 2WD Only}
Front Wheel; Inner
$2.57$0.00$2.57
SKF Part # 13671
Wheel Rear; Inner; Spicer 35 Axle (Only 7 Remaining)
$6.71$0.00$6.71
SKF Part # 16747
Wheel Rear; Outer; Spicer 35 Axle
$8.95$0.00$8.95
from another forum:
This may be easier to work from the axle side of things ... the axle-shaft diameters are different enough to see easily... (at least with these two axles)
With the 8.25 Chrysler rear axle:
Timken p/n: 8835S
SKF, BCA, or CR p/n: 16044 CR
With the Dana 35 rear axle:
Timken p/n: 8660S
SKF, BCA, or CR p/n: 13990 CR
cannot verify accuracy, but posted for info anyway....
Keep in mind that the seal will be different depending on whether the axle is a c-clip style D35 or the earlier, non-c-clip style. What year is the vehicle, and do you know if the rear axle is the original axle?
Don't the parts stores ask you what year the vehicle is?
