Matthew Currie
NAXJA Member #760
- Vermont, land of big clay
I've had two AX-15's, one still on the road at over 250K, the other retired at 263 largely owing to body rot. The AX-15 is good and durable. The clutch is pretty robust too. I had to replace the clutch in my 99 at well over 200k not because of disk wear but because the throwout bearing failed and ate through the diaphragm. But in general one can't complain about that kind of longevity.
The only reservation I have about the stick shift rig is that off the road the factory gearing is pretty tall. I don't do serious off roading, nothing more than logging roads and the like, but you definitely need low range for this if you don't want to be riding the clutch. Of course there is a low range, so all you have to do is use it. I've towed small trailers, and extracted a few stuck vehicles in winter with mine, and that's no worry, but again, if you're pulling someone out of a ditch, you'll definitely need low range.
I've also had an AW4, and it's fine too. Best slushbox out there if that's what you prefer, and also very durable. My automatic 87 got just as good gas mileage as the later sticks. That one, as well as a 93 that a couple of my kids owned for years, went well past 200K miles with zero transmission issues.
I'd still look for the AX-15, but would not turn down a good AW-4 if that's all you can find.
