bigalpha
Moderator
- Tucson, AZ
1. What do you make of the 'b' pin at the connector under the hood not registering anything when I connect it to 'f' pin; but getting a resistance when i connect 'f' pin to batt neg pole?
2. Can I have a gunky and malfunctioning NSS even if I experience no typical NSS symptoms? If so, will this have any impact on the tranny problem?
3. Is the TPS still alright, even if the Voltage is somewhat low?
4. Where does the wiring run to the solenoids? It goes down the firewall, then does it go over the top of the tranny?
