aw4 - 2wd to 4wd
Andrew T
Houston, TX
I came across an aw4 that's from a 2wd, and I'm looking for a 4wd. Is it possible to swap some parts over from mine to the rear of the 2wd one to make it a 4wd tranny, or is that either impossible or just a waste of time? Any input is appreciated.
Andrew
It's probably not worth the effort. There are a lot of good boxes out there for 4WD's that can be had for a couple hundred bucks.
It would mean a complete tear down and rebuild because you have to swap the output shafts- the one on the 2WD transmission is longer than the 4WD variety. It's not just a simple matter of replacing the tail stock with a TC adaptor.
CheapXJ said:
couldn't one just cut the shaft down and then swap the tailhousing?
No. You would have to cut the appropriate splines on the new end of the shaft because you just cut the splined end off.
