96 XJ Sport
- Bardstown, KY
Well, here's what the testing yielded:
-Battery voltage at C8, C10, D14, and D16 was 12V give or take 0.2 (with key and shifter as indicated for each pin).
-Battery voltage at C9 was 0.00 (with key on and selector in D as indicated, but should be 12V).
-Voltage at D2 (TPS input) was 0.7V with closed throttle and 3.8V with gas pedal to the floor. Test indicates that it should be the opposite?
-TPS ground at D3 was 0.00V.
-Lockup solenoid at C14 read 12.2 ohms and 14.5 ohms on subsequent readings before and after driving.
-Solenoid #2 at C15 read 32.8 ohms and 35.5 ohms before and after driving.
-Solenoid #1 at C16 read 513 ohms and 340 ohms before and after driving.
So the correct diagnosis would appear to be to replace solenoids #1 and #2. Is that correct? What about C9 reading 0 volts in the D position? I don't know what to do with that one.
