S Spooky NAXJA Forum User Sep 30, 2003 #1 I have the calipers removed and the 3 12point 1/2" bolts removed from the unit hubs but I can't get the hubs to budge. Anyone have any tips on how to remove these? I'm trying to remove the hubs and axles as one assembly. TIA
Ralph NAXJA Member #149 Location Lubbock, Texas Sep 30, 2003 #2 First spray a little PB Blaster where the hub seats on the knuckle. Reinstall the 12 point bolts about half way. Smack the bolts with a hammer. This will drive the hub off. As you work the hub loose, use more PB Blaster. RR3
C ChiXJeff Curmudgeon NAXJA Member Location SE MN Sep 30, 2003 #3 Ralph said: Reinstall the 12 point bolts about half way. Click to expand... Uh........ use a set of sacrificial bolts instead. Chances are that you'll mushroom the heads badly. It's also a bad idea to use a slide hammer on the wheel studs, unless you're planning on replacing the hub. That abuses the side of the race horribly.
S Spooky NAXJA Forum User Sep 30, 2003 #4 Thanks. already got one off with a bigger hammer. hope the races will be ok.
