Arrrggghhh fuggin torx....
RichP
Effort, Pa
Specifically the t50's on the track bar and that hold the roll cage in...the accessable ones came out easy, the two hard to get at mothers won't...
Time to bring out the 1/2 milwalkee and some drill bits I think...
torx on the track bar? i dont recall mine having any... unless you mean the frameside mount...
Yea, the TJ has one down on the axle, T50, what a sob that was.... we're both bleeding....but got it out. Now comes the bases of the roll bar.... no torx going back in there either. Think I'll just take all the new bolts and throw them in the antiseize bottle and shake... :laugh3:
I replaced the axle side trac-bar bolt on mine when I installed the adjustable. Replaced with a dealer unit for a '96XJ. Not only did it have a torx head it was about a half inch too long.
I made it work though.
hahahaha
trying to drop the windsheild?
good times - i installed a buddy's safari lights on his TJ and taking all them torx off was anoying as hell...
best of luck
if its any consolation - im bout to go grind my knuckles off while working on getting this 9" into my rear end...
In the garage are you?
Take it inside onto the carpet...
Your knuckles will thank you...
oh and btw... This really belongs in the den
Do we all really think that much alike, man thats scary.... :laugh3:
Oooo, kinky! Is Billy helping you out with that?
yes we do
Gil BullyKatz said:
I'll be the first to admit...
That's ALL I think about...
Like they say, every 15 seconds....
