are 8.25's usually a little noisy?
philip_g
back in CO
I've noticed more than what I'd consider normal gear whine on the 2000. Since I've only had D35's and a D44, I thought maybe it could be normal before I start worrying about pulling it out.
So does yours whine a bit? It's pretty noticeable at around 50mph.
Skwerly said:
I've heard yes and no. If you know someone, I'd have it checked out ASAP.
that's basically what a search turned up, it's tough to quantify a noise over the interweb so I guess I'll get an opinion on it.
No unusual noise noted for 8.25.
Rumbles and growls are either bad bearings, or not enough coffee/doughnuts in the morning.
Whinning is usualy gear noise or bad temperment.
Did you recently do gears?
He just bought this Heep. It would not hurt to check the lube.
Edit: OK, it could hurt if you drained it and the oil had sparkles or chunks in it. LOL That would be painful.
no growls, just a loud howl on throttle. usual gear whine sound but louder.
I need to do plugs and oil tomorrow anyway, I'll put fresh lube in
I'm almost afraid to mess with mine. The limited slip is working so well.
I've scrapped a couple that had bad carrier bearings. Sounded like gear growl.
I've had a 29spline 8.25 in my 99 and swapped in a 27spline 8.25 on my 92. Neither have produced any sort of noise, in fact there is no axle that should have gear noise as a normal thing.
I don't know that's completely accurate, I haven't heard many diffs that don't whine at least a little.
stupid no gasket usin so and so's :mad: I HATE RTV.
Popped the cover, fluid was clean, very clean so I assume it's been changed recently and all the gears looked pretty much new.
if it DJ's on me going down the freeway and you never hear from me again, oh well.
I have a whine since I went to 4:56 gears. I cannot tell if it is the D30 or the 8.25. It is a low speed whine and that is hard to hear, unless the radio is off and the windows are up. This is my first re-gear, so I have no previous experience.
I was told here, that the lower the gearing the more likely you'll hear a whine.
We popped the covers to check for wear at 600 miles and everything looked peachy!
Did you have the tires off the ground when you pulled the cover and drained the fluid? Did you give the diff a good spin? If the carrier bearings were worn, you should have been able to hear them with the fluid drained and a good spin of the tires.
Nah didn't think to try it
