BUCKET
- california
I just did the the two piece axle swap with the larger u-joints and 4340 shafts on my dana 30 that went really easy but the problem is my arb is now leaking.The line coming in the top of the diff, is there some kind of compression fitting or does it just push into the supply line. Had to remove the carrier for the axle swap must of not installed right it looked good
now have lots of air coming out of the the diff vent tube, and my compresser keeps cycling .
