I ordered a new APN Tri-Y header and noticed that one of the welds at the collector has a pin-hole. I put a little water in that runner and verified that it does leak.
I see 3 basic options, what would you do?
1) Leave it and use as is
2) Weld it up with a small tack weld
3) Send it back and hope the new one doesn't have a similar issue
My concern with welding would be that it might affect the joint and make it more likely to crack, but I am probably over-thinking it since it would be a tiny spot weld.
