Anyone with coilovers in the front?
zjmikey
SoCal
I know there are some guys here with Coilovers in the front, If you do can you post some pics??
trying to get some ideas...
I am picking up my Sway-a-ways's this weekend. They should be done in the next couple of weeks as long as the under-hood fabrication goes OK. I have to relocate my ARB compressor and my coolant bottle. I am getting the 14" 2" remote res. version. and will set it up with about 5" of up and 9" of droop.
SeanP
that looks like about what I want to do, my issue is the cross brace is gonna be a beatch... because I have the V8 (its a zj) but the front geometry is still the same..
I am just tired of the damn coil rub issue with the trackbar, and coilover are alot more compact...
I figure I sell my Acos, my Bilsteins, and my coils, its not much different except the fab cost.. .
how did you mount the hoops to the unibody, did you make a subframe and they mount to that??
I already have a subframe that goes from the crossmember to the rear, I guess I would need to extend it up to the motor mount area...
Thanks for the pics, if you have a link to more that would be cool..
Ill ring in! :D
This is what I have done up till now:
Big dawg 31" tires (wont roll out of the garage on 37"s
Arms need to be shortened and Hoops need to be fiinished
why weld the tabs to the cast? looks good just curious though. I made mounts for my c/o
Farthest point outward. out of the way of the radius arms. Really no room on the axle. All the buggies are doing it, why cant I? :D :D
I get first dibs on the ACOS
