Looking for anyone in my area that I can pay to come by and help me through a electrical issue. I am in El Dorado Hills, CA (30 mins from Sacramento). Drove the 89' XJ into the garage, did a bunch of work to suspension, changed oil pan gasket and rear main seal, tranny pan, tranny cooler lines, motor mounts, etc. Went to start it after all work was complete, no start with no spark. What I have done: switched out multiple ignition/sensor parts from another running XJ. Replaced my CPS twice with the last being an OEM factory sensor, new distributer, cap, rotor, plugs, new battery, new water temperature sensor, new ignition switch, cleaned all connections, refreshed all ground, and more!
So when I turn the key on, no 4 second prime to fuel rail, when cranking I get appropriate fuel pressure but no spark. Also new, the water temperature gauge is now full right when cranking.
Will pay a mechanic to come by. I have all the tools you will need here.
Please lmk if you or if someone you know can help.
Thanks, Mark
[email protected]
Thanks, Mark
[email protected]
